First time water cooler
  • Water Cooling
  • Cases
  • Cooling
  • Overclocking
  • Product
May 24, 2012 5:56:22 PM
I want to water cool my gtx 560 ti and my 2600k. I have a Nzxt Phantom case. Will these things work?
Current Specs:
2600k
560 ti (MSI twin Frzr II)
Sabertooth p67 chipset
CPU Block:
http://www.xoxide.com/swiftech-apogeehd-waterblock-whit...
GPU Block:
I need help in this area. I want full coverage please help me find one
RAD:
http://www.xoxide.com/swiftech-mcr120-xp.html (back of case)
http://www.xoxide.com/swiftech-mcr220-xp.html (top of case)
Pump:
http://www.xoxide.com/swiftech-mcp655.html
or
http://www.xoxide.com/swiftech-mcp355-pump.html
Res:
http://www.xoxide.com/frozenq-liquidfusionvseries250mmr...
OR
what is the name of this res in the photo
http://ep.yimg.com/ca/I/yhst-39083765508394_2210_108583...
Also what liquid would u recommend? and What size tubing ? give me any advice you can
More about : time water cooler
a c 190 K Overclocking
May 24, 2012 6:02:32 PM
Hoo-Rah on the res there mate :)
just one? they look awesome in pairs you know...
second one looks like a bitspower job, ok but not as visually damaging as the t-Virus res
I'd swap the Cpu block for a Raystorm,
coolant? distilled water, the UV cathode will keep your water clean btw, its a nice side effect
655 for the pump, you may want to expand later on and you will have the power to do that easily rather than buying a new or additional pump
and I don't think you can get Fc's for the 560Ti, its universal blocks and ramsinks unless anyone knows of a compatible block
Moto
m
l
May 24, 2012 6:08:11 PM
Whats raystorm and why them?
m
l
May 24, 2012 6:10:55 PM
Xspc raystorm,
currently the best mainstream block out for the price, apogee's are still good, if you prefer the looks then have that by all means, but you'll have better performance form the Xspc block
Moto
m
l
May 24, 2012 6:24:20 PM
Can i change the led's in the block ? also is there a good guide for putting a universal waterblock and memory heatsinks on the 560ti
m
l
a c 337 K Overclocking
May 24, 2012 6:25:34 PM
That's exactly what I did...I own 2. And...it's in the watercooling sticky.
m
l
May 24, 2012 6:44:28 PM
i cant find the article in the sticky? direct link ? also i think i have my cart made up ? n can u recommend some memory heatsinks for the 560ti?
m
l
May 24, 2012 6:51:13 PM
nvm found it and so i just put copper heatsinks with thermal paste on them on the mosfets and inductors ?
m
l
May 24, 2012 7:44:46 PM
If you have a reference 560ti, the full-cover heatsink will. They are meant for use with Swiftech MCW60/80/82 blocks, but might work with others.
You wouldn't apply normal RAMsinks with thermal paste; you'd either use thermal adhesive or thermal tape.
m
l
May 24, 2012 8:39:38 PM
so that swiftech thing will use thermal paste tho right ?
m
l
May 24, 2012 8:43:09 PM
Yes, but ramsinks come with their own pad, you just peel the backing off and fit in place
Moto
m
l
May 24, 2012 9:12:01 PM
I believe it uses thermal pads and is actually secured to the card using the cooler mounting holes and screws.
m
l
May 25, 2012 2:48:52 AM
alright also do ether of u have ne experience with nzxt phantoms? im trying to figure out the best way to run this within the case. I want it to go as following
res -> pump
pump-> dual rad (top of the case)
dual rad -> CPU
CPU -> single rad (back of the case)
single rad -> GPU
GPU-> res
and it would be bad to run one big tube from the bottom on my case to the top of the case right ? like if i went from pump to dual rad n the pump was at the bottom of the case?
m
l
May 25, 2012 3:17:56 AM
That loop order is fine, and no, no problems with that length run of tubing, its probably not even a foot
Moto
m
l
May 25, 2012 4:23:58 PM
is it bad practice to use a 90 degree fitting ? also what tube size should i use ? and what r the benefits with each tube size?
m
l
May 25, 2012 4:27:32 PM
Theres no real difference in tubing size, the flowrate is not massively affected, although smaller diameter tubes will hold head pressure slightly better again, its negligible
90' fittings used to be frowned upon heavily but people are starting to use angled fittings more often, its still 'better' to use a softer angle if possible imo
but I have three 90's in my current build with no issues
Moto
m
l
June 7, 2012 2:42:31 AM
i use a NZXT Phantom. remember to check how much clearance you have from the top of the case to your ram clips. mine measured at roughly 5.5cm.
This means you have enough room for a 30mm rad + 25 mm fan which is the standard size. however, you could fit an EX radiator with some 12mm scythe fans and that would probably do the job. Its your choice entirely though :)
also. you'll notice that the bottom left hdd bay can be removed as it is only held down with a few screws so you could easily fit a 120mm rad in there without voiding warranty. the only thing i'd worry about having the setup you posted earlier with the whole cooling setup is that it looks like those fans will be intaking air and they're both covering the main exhaust locations so when you blow the air in it'll heat up then naturally hot air rises and it wont be able to. leaving it floating about your pc case heating up your radiators. if you had one down the bottom intaking the cold air from below your case then have the top one exhausting then it should work a lot better.
(edit)
sorry i just realised you only used that to reference the Res
Crest
m
l
