Hey Everyone,
I work in Adobe Premiere and After Effects so I need a fast scratch disk to work on.
I am looking to eventually put two cards in SLI in the rampage and also have a SAS card for my two Fujistu's in raid 5.
My build:
Motherboard: http://www.newegg.com/Product/Product.aspx?Item=N82E16813131642&cm_re=rampage_iii_extreme-_-13-131-642-_-Product
SAS Card: http://www.newegg.com/Product/Product.aspx?Item=N82E16816118105
GPU in 2-Way-SLI: http://www.newegg.com/Product/Product.aspx?Item=N82E16814130551
HD'S: http://www.newegg.com/Product/Product.aspx?Item=N82E16822116059
My question is would the including of the raid card downclock one of my GPU's and make it 16X/8X/8X?
If that's the case should I go with the ASUS P6T6 board with the n200f chip?
Asus P6T6: http://www.newegg.com/Product/Product.aspx?Item=N82E16813131358&cm_re=p6t6-_-13-131-358-_-Product
Thanks
My build:
Thanks
