Build is as follows:
i7-860 processor
ECS P55H-A(1.0) mobo
G.Skill F3-12800CL7D 2x2GB ram
ATI 4870 gpu
700w OCZ power supply
2x WD 640 GB Black hdd - raid 0
CM Hyper 212+ cpu cooler
Windows 7 x64
Everything is working great, except a couple benchmarks(from Passmark Performance Test) which aren't making sense to me:
For reference: "This Computer" is my system in its currently overclocked form(3560 mhz and memory timings optimized). "ECS P55 stock" is the system without any overclocking or memory tweeks. All other systems in the comparison are the same processor with the same amount of RAM at stock speeds.
As you can see, my CPU - Integer Math is WAY low, and my CPU - Floating Point Math is only getting to where it should be when overclocked.
My memory also seems to be lagging a bit in Small Block and Large RAM, though my memory lags in all the tests.
Any ideas what's going on? I included some results from ASUS and MSI that are exhibiting the same symptoms, but I had to search for them. Most of the results I compare against are in the upper segment. Any help would be greatly appreciated.
i7-860 processor
ATI 4870 gpu
Windows 7 x64
