I have installed windows 7 and haven't udpated any drivers for it yet. I went back and installed my graphics card into the computer before disabling the integrated intel hd 4000. After I installed the gpu and hooked it up to my monitor there is now a blank screen as if to detect no card. Sapphire instruction book said to uninstall that before hand but I thought I might have issues if it doesn't detect the new gpu and I have no integrated graphics to fall back on. I basically left intel hd 4000 enabled. I tried using different cables (vga, hdmi) while the power was still on is that ok? I think I'll end up having to remove the graphics card but I cannot properly shut down windows when I can't see anything. What should I do?
System spec
Corsair Graphite Series 600T CC600TM Mid-Tower Gaming Case
ASRock Z77 Extreme4 LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
SAPPHIRE Radeon HD 7850 OC 2GB 256-bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video Card
CORSAIR Professional Series HX750 (CMPSU-750HX) 750W ATX12V 2.3 / EPS12V 2.91 SLI Ready CrossFire Ready 80 PLUS
SILVER Certified
Crucial M4 CT128M4SSD2CCA 2.5" 128GB SATA III MLC Internal Solid State Drive (SSD) with Transfer Kit
CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Low Profile Desktop Memory Model CML8GX3M2A1600C9
Asus VH238H Black 23" Full HD HDMI LED Backlight LCD Monitor w/Speakers Model #:VH238H
LITE-ON DVD Burner - Bulk Black SATA Model iHAS124-04 - OEM
System spec
SILVER Certified
