I recently upgrade my computer form 4.5 years setup.
The primary hard drive is the Kingston HyperX 120GB SATA 3 Sandforce SSD.
I did some test (AS SSD and the CystalDiskMark)
the read speed is like sata 2 speed, read seed seem to be ok except 4k is perform like sata 2.
Here is the print screen.
http://imageshack.us/photo/my-images/831/unledanq.png/
http://imageshack.us/f/507/unled2m.png/
The motherboard is the ASUS P8Z68-V PRO/GEN3
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131790
the SSD is using the sata 6 cable provided by the motherboard plug into the intel sata 6 port, i also try the mavell sata 6 port, is even slower.
Not sure if this has to in fact I installed Windows Vista 32 bits first then upgrade to Windows 7 64 bits. If I do a full installed of windows 7 64 bits will it fix the issue?
