9800gtx power requirements compatibility with my rig?
http://img123.imageshack.us/img123/3770/p10100078va.jpg my psu
system specs:
19'' samsung lcd
currently running 8600gt 512mb ddr2
c2d 2.2ghz E4500
2 hdd = 160gb WD + 1tbWD caviar green
intel board dg31pr
looking for gpu upgrade, prefrence nvidia
plz help if the card would run on my rig with the psu i have
not looking for upgrade of any other unit just the gpu till now ,not even the psu
recommend gpu which can run on 450w colorsit supply
looking for a better gpu than my 8600gt
plzzz help i am really confused about this ..
thnx
Graphics card Master
Your PSU is not the greatest and it is hard to recommend anything that needs extra power from it 9800GTX req 26amps on the +12 volt rail you have only 19amps.
Cards that most likely will run on your psu are HD4670 or GF GT240. Anything more powerful is a gamble. Take a look at this http://www.tomshardware.com/reviews/best-graphics-card,...
And here is a test of the GT240 since it is not included in the other link. http://www.tomshardware.com/reviews/geforce-gt-240,2475...
thank u for ur reply man really appreciate it
guess i am gonna have to get the supply changed as well ..
gonna b hard as i wanted to upgrade and play games better than my 8600gt
not thought that whole rig would need to b changed for it lol
well thnx anyway will think of an alternative or would have to do with the same rig for the timebeing
Graphics card Authority
That is a very very shitty PSU.
Don't think about adding any card.
If your budget is small then get Corsair CX400 or Gigabyte Superb 460w minimum.
They should work with 9800GTX.
Ask the community
