As the title states, I am having serious issues installing this card. I am by no means a computer expert so any help would be GREATLY appreciated. I can't figure out why this card won't work.
My current setup:
Mobo: ECS P4M890T-M (V1.0)
Chip: Intel Celeron D 2.80 mhz
PSU: 550w
Ram: 1.5 ghz ddr2
Previous video card: ATI Firegl v5100 PCI-e
I uninstalled my old ATI v5100 card and drivers from add/remove programs, and rebooted on my onboard video to install drivers. When I tried to install the nVidia drivers, it failed, giving me "no drivers for current hardware" prompt. I tried the latest drivers, older drivers, and REALLY old drivers. Also, the system goes into continuous reboot when I install the card. I don't understand why none of this is working, considering I do have a 2.0 PCI Express x16 port.
Is there some step I am missing? (bios settings, registry cleaning?) Could the card be bad? Is some part of my setup incompatible?
Full MOBO Speficifations:
EliteGroup P4M890T-M (V1.0) - motherboard - micro ATX - P4M890 specifications
• General
• Product type (AE) Motherboard
• Form factor Micro ATX
• Width 9.6 in
• Depth 8.3 in
• Compatible Processors Celeron D , Core 2 Duo , Pentium 4 , Pentium D
• 64-bit Processor Compatibility Yes
• Mainboard processor socket LGA775 Socket
• Mainboard / Multi-Core Support Dual-Core
• Chipset Type VIA P4M890 / VIA VT8237R Plus
• Data bus speed 1066.0 MHz
• BIOS type AMI
• Storage key information Serial ATA-150 (RAID)
• Power connectors 24-pin main power connector , 4-pin ATX12V connector
• Processor
• Installed Qty (Max Supported) 0.0 ( 1.0 )
• Memory
• Cache Memory Type None
• Supported RAM Technology DDR2 SDRAM
• RAM Installed ( Max ) 0.0 MB / 4.0 GB (max)
• Supported RAM Speed PC2-4300
• Video
• Graphics Controller VIA UniChrome Pro
• Video Memory Shared video memory (UMA)
• Audio
• Audio Output Sound card
• Audio codec Realtek ALC655
• Sound Output Mode 5.1 channel surround
• Audio output compliant standards AC '97
• Telecom / Networking
• Modem None
• Networking Network adapter - VIA Tahoe VT6103L - Ethernet , - Fast Ethernet
• Features
• BIOS Features Hyper-Threading Technology , APM 1.2 support , Multi Boot , ACPI 1.0 support , DMI support
• Expansion / Connectivity
• Expansion Slots Total (Free) 1.0 Shared PCI / CNR - LGA775 Socket , 1.0 PCI - DIMM 240-pin , 1.0 Memory , 1.0 Processor , 2.0 PCI Express x16
• Storage Interfaces ATA-133 - connector(s): 2 x 7pin Serial ATA - 2.0 device(s) - RAID 0 / RAID 1 , Serial ATA-150 - connector(s): 2 x 40pin IDC - 4.0 device(s)
• Interfaces 4.0 x Audio - VGA - Mini-phone stereo 3.5 mm , 1.0 x Microphone - Line-in - 25 pin D-Sub (DB-25) , 1.0 x Hi-Speed USB - Floppy interface - RJ-45 , 1.0 x Display / video - Line-out - Mini-phone 3.5 mm , 1.0 x Parallel - Generic - 9 pin D-Sub (DB-9) , 1.0 x Network - Ethernet 10Base-T/100Base-TX - Mini-phone stereo 3.5 mm , 1.0 x Audio - Generic - 4 pin MPC , 1.0 x Keyboard - RS-232 - 6 pin mini-DIN (PS/2 style) , 1.0 x Serial - IEEE 1284 (EPP/ECP) - 15 pin HD D-Sub (HD-15) , 2.0 x Storage - Input - 4 pin USB Type A , 1.0 x Audio - Line-in - 6 pin mini-DIN (PS/2 style) , 1.0 x Mouse - 34 pin IDC
• Additional connectors (optional) 4 x Hi-Speed USB
