Solved
BEST 80MM BLUE LED 3 PIN FANS? READ!!!
What are the best 80mm Blue LED 3 PIN fans available on Newegg? I need them to cool my graphics card. I do not care how loud they are, the most powerful is what I want.
Thanks!
4 answers Last reply Best Answer
More about best 80mm blue fans read
  1. This one is a 8000 RPM fan 108CFM
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835706041
    Pretty loud but it should do it has a PWM connector and it will work on a 3pin.
    That looks great but I need a Blue LED one D:
  3. Best answer
    Awe crap lol. Totally forgot that.
    Here you go. Might get this myself too.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835150037
    Or this one
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835129007
    Also this one but it is not offered on NewEgg
    http://www.quietpc.com/products/80mmfans/gel-wing8-uvblue
  4. Best answer selected by Arlen10.
Heatsinks Graphics Cards LED Monitor Overclocking Product
