Right click doest work
Hello,
My right click mouse does't work anymore after I probably disable something in the start-up menu. Does any know which one?
3 answers Last reply
More about right click doest work
  1. go to control panel and find mouse open its properties You may have a bigger problem as you need to right click on the mouse in the control panel but try it anyway as it may right click in the control panel
    right clicking the mouse in my panel brings up the setting
    failing that unplug then replug your mouse and see what happens ok
  2. forgot to say reinstall the mouse with the cd you got with it
  3. Oh yeah, that will help. In case windows doesn't recognize your mouse, use the install cd.
Mice Components
