NZXT Phantom Cooling… Best Practices?
Hey Guys,
So I've got a new build and I'm not doing anything crazy or extreme, but I wanna make sure I have the right cooling config. Nothing runs too hot now, but I'd like to improve airflow regardless.
I'm running a core i5 3570K on an MSI Z77-GA45 with a Galaxy GTX 680 and a Corsair AX-850.
I'm using the stock fans that came with the case, and want to add a side 200mm fan, same for the top.
I read somewhere that the side fan could be a bad idea; I wanted to get your thoughts before buying. Also, I'm already aware that I'm stuck with NZXT's proprietary fans, is there anything I'm missing?
Thanks in advance guys!
2 answers Last reply
More about nzxt phantom cooling practices
  1. The side fan could potentially be bad. I've got the phantom 410. I have a side case fan blowing in cool air directly onto my GPU. That side fan helps keep my GPU three degrees cooler during bench marking. I'd recommend you conduct a test to see if it helps or hurts your set up.
Heatsinks Cooling Overclocking
