Hi all,
I'd like some suggestions regarding a motherboard upgrade. The one I'm using currently has finally gotten on my last nerve. It is a Biostar model TG31-A7. I've never had strange problems like this although I haven't done a whole lot of computer builds. When I first built this machine it would randomly shut down. It seemed that for whatever reason it's due to having 2 RAM sticks inserted simultaneously. I remember testing both RAM chips and each working individually. So instead of my preferred 4 GB I've been running it with 2. I figured fine, I'll just deal with it since I don't want to RMA.
However, I recently got a video card. It was running fine I thought, but then I tried to render a project with Vegas and I'd get a blue screen and immediate restart every time. I didn't know what the problem was, but I removed the new video card and rendered while using the mobos video output and my projects rendered fine. I don't know why these things are happening, but I'm pretty sure it's the motherboard, which as far as I can tell isn't made by a quality manufacturer although it was rated high on newegg when I bought it: http://www.newegg.com/Product/ProductReview.aspx?Item=N82E16813138121
Most of the time the board works, but weird problems like this just aren't going to cut it for me anymore. So I'm thinking about buying this Gigabyte: http://www.newegg.com/Product/Product.aspx?Item=N82E16813128358 I usually just go to newegg and look through the top sellers till I find the one that best suits my needs.
The other parts I have are:
Q6600
OCZ 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400): http://www.newegg.com/Product/Product.aspx?Item=N82E16820227248&Tpk=OCZ2P8004GK
Antec True Power Trio TP3-650 650W ATX12V SLI Certified CrossFire Ready Active PFC Power Supply with Three 12V Rails: http://www.newegg.com/product/product.aspx?item=n82e16817371001
ARCTIC COOLING Freezer 7 Pro: http://www.newegg.com/product/product.aspx?item=N82E16835186134 (Actually this looks like an updated version. Mine has the plastic pins you push in instead. It should fit the new mobo correct?)
And the new video card: ASUS EN9600GSO/DI/512MD3/V2 GeForce 9600 GSO 512MB 128-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card: http://www.newegg.com/Product/Product.aspx?Item=N82E16814121320
Unfortunately I don't have an ATI video card for Crossfire, but this mobo still looks like the best one. I looked through other Gigabyte mobos http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2010200280%2050001314%201070631947&name=Core%202%20Quad%20%2f%20Core%202%20Extreme%20%2f%20Core%202%20Duo# and the above one seems like the only standard ATX which supports DDR2 800 RAM.
Anyway, this is a long winded post, but at this point I want to make sure I get the right parts. Assuming it is indeed the mobo which is at fault.
If you have some thoughts please let me know.
Thanks!
Q6600
Thanks!
