Tom's Hardware > Forum > Laptops & Notebooks > General Laptops & Notebooks > A nasty display problem on a Thinkpad T20
Forum Laptops & Notebooks : General Laptops & Notebooks - A nasty display problem on a Thinkpad T20
Archived from groups: comp.sys.laptops (More info?)
Since a picture is worth 1000 words, please find below my 3000 word
essay on "A nasty display problem on a Thinkpad T20". I'd appreciate
any input on what the faulty component can be:
1. Inverter card
2. System board
3. LCD display
4. Other
Notice that the leftmost 2 cm of the screen is fine (the fuzziness is
just high compression of the JPG image). Using an external display
works perfectly. So, what do you think is wrong?
I ask because I need to know what to replace. I'll try a DIY job on
this one because IBM won't fix it for me. Sure, my warranty has
expired, but I had the exact same problem "fixed" under warranty less
than a year ago. I don't know what they did to solve it then, but it
worked when I got it back. IBM apparently only has a 3 month guarantee
on repairs.
http://www.entek.chalmers.se/~niclas/DSC01758b.JPG
http://www.entek.chalmers.se/~niclas/DSC01759b.JPG
http://www.entek.chalmers.se/~niclas/DSC01764b.JPG
Sponsored Links
> 1. Inverter card
> 2. System board
> 3. LCD display
> 4. Other
> on repairs.
4. Other... You are going to have to open the unit anyway, so once you
get in there, first check the connector to the LCD on the mainboard.
You could get lucky and it's loose. If it were the mainboard/video
chipset, the external monitor would not work, unless it is in the analog
signal processing for the LCD, then it's eBay for a board.
Q
Reply to Anonymous
Ooh! ooh! I had this EXACT same problem on an a20m about a year ago! I
didn't know what was exactly wrong either, but I took a guess and
replaced the LCD panel. Now it works fine! It was about $150. I'm a
big fan of the field service manuals IBM publishes on their website.
That's how I replaced mine.
Good luck!
nicke2323@hotmail.com (Nick E) wrote in message news:<a198a7b.0407011031.4232c9cd@posting.google.com>...
> 1. Inverter card
> 2. System board
> 3. LCD display
> 4. Other
> on repairs.
Reply to Anonymous
There are 698 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
  • 01:00 WookinPaNub won the Uniformed badge
  • 01:00 kwadams won the Uniformed badge
  • 21:57 brockh won the Sophmore badge
