Before install freezer xtreme cpu fan should i clean off existing thermal grease
Last response: in CPUs
Yes but i recommend being extra-careful. Remember that any static could end your cpu's life, and any damage on the underneath connectors could make it unusable. Also avoid having grease ending up on sides or under the cpu, obviously.
I have not tried with alcohol yet, I usually just grav the softest tissue i can find arround.
Ask the community
