Tom's Hardware > Forum > Computer Peripherals > CRT Monitors > Monitor help (very strange blurriness problem)..
Forum Computer Peripherals : CRT Monitors - Monitor help (very strange blurriness problem)..
For some reason, in Windows, the center of the screen and the left side is blurry. I've tried cleaning the Monitor, checked the connections, fiddled with the Monitor options, checked around the Monitor Settings within Windows [refresh rate, etc], and I can't seem to fix it. I've also tried updating both my graphics and Monitor drivers.
I can play games fine, they are crystal clear; but on the Windows Desktop, there is blurriness in some areas, which makes it painful on the eyes. Any idea as to what caused this? And any idea on how to fix it?
It was fine at lunch (yesterday). I came home, and found that it's blurry.
Sponsored Links
if u gave info on what monitor it is and stuff like that then we could help.
Reply to shm0
ok go to the monitor options(on the actual monitor) and try the button/option
degauss
this may fix the problem as you may have had a power surge and the magnetic plates in the monitor may be effected funny.
that is all i can think of
Reply to alltaken
There are 1280 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
