Can anyone help me perform this mod please:
High-pressure mount for H100
Firstly, does anyone know where to buy the 'extra beefy asus backplate'?
For the bolts and springs, I'm thinking this kit might be appropriate:
Mounting kit
Anyone know if that will work?
If you look at the same type of mount here (but on an air-cooled):
High-pressure mount for air-cooled
It shows the nylon washers between the bolts and the back-plate.
Do you also need nylon washers to go either side of the motherboard, to insulate?
If so, will you need more nylon washers than that kit has in it? And more metal washers?
In fact, looking at this picture (sorry, I couldn't work out how to insert the picture here - the picture you can see of the assembled screw when you click on the 'Mounting kit' image above) - can someone just clarify the exact order that the parts go in (as in, bolt, nylon washer, backplate, nylon washer, mobo, nylon washer, etc). I know it shows it in the High pressure air cooler thread above, but I want to be sure about it.
Plus any other advice about how to correctly perform this mod appreciated!
Connected with the above mod...
Lapping the CPU/H100:
When I've read of this, I hear people say 'my one was convex, concave, raised on one side' etc. How to tell this? By eye? Spirit level?
So, how to tell when it's finished? I understand a mirrored finish is perfect. But how to tell if it's 100% flat and each bit fits perfectly flush onto the other bit?
Thanks in advance for any help!
Mounting kit
