Dear Tom's Hardware Members,
I am currently a new member on this wonderful site and I would gladly appreciate help on my
new Gaming/General System that I will be building in the next 1-2 months.
Where I will Buy from:
I live in Australia and the website that I will be purchasing my components from is,
www.tigerdirect.com
Note: Yes, I will be the shipping parts to AUS because it actually ships to Australia unlike many US stores and I simply cannot find a cheap store in Australia. If you have any better websites with exceptional customer service, reliable and are cheaper then TigerDirect please feel free to recommend them. (Note: I'm not 100% sure if the Shipping Fees and Price in total will be cheaper than buying directly from Australia) Please Help me on This.
What this System is build for:
This is a build that I hope will last 2-3 years and will be used for Gaming and General usage.
I am into both RTS/RPG and FPS games. I will also be using this computer to accomplish High-School homework and assignments.
E.g: DotA, WoW, CS:S, CS1.6
Note: I am not a hardcore 24/7 gamer but I will Overclock my CPU and maybe Crossfire my Graphic Cards.
My Computer Parts:
Case: Nzxt Lexa S
MotherBoard: Asus Crosshair III Formula
Unfortunately I can't find this mother board on TigerDirect anymore and I would appreciate if someone could recommend another board with pretty much the same features. Also it would be thankful if the motherboard would support CrossfireX as I will be connecting two 5770's
Edit:According to comments I might just go with one 5770 or 5850.
CPU: AMD Phenom II 955 Black Edition
Graphics Card: 2x ATI Radeon HD 5770 or 5850 (I will Crossfire these in the future)
Moniter: Acer H233Hbmid 23" Widescreen LCD moniter
CPU Aftermarket Cooler: Thermaltake SpinQ CPU fan
I will be OverClocking my CPU to approxmately 3.7Ghz and I definately need a good CPU cooler but I am not sure if the SpinQ will fit in the Nzxt Lexa S case. (Help Needed)
HDD: Western Digital Velociraptors 10,000rpm 300GB
Optical Drive: Plextor Px-B320SA Blu Ray, CD, DVD Read and Writer (LightScribe Inc.)
Memory: Kingston HyperX 4GB DDR3 1600mhz RAM
Case Fan: Ultra Performance 120mm Dual-Ball bearing Case fan
Note: Getting a case fan because there are 5 fan slots in the Nzxt Lexa S case and only 4 supplied.
Power Supply: Corsair 750w Modular Power Supply
Thermal Compound OCZ Freeze Thermal Compound
Note: I wanted a cool PC so I thought of getting rid of the stock paste and adding my own after market one. Only problem is that I need to find a Thermal Paste remover
(Need Recommendations)
Keyboard: I can't decide which keyboard to use but the ones I've been looking at are,
Razer Tarantula-
Razer Lycosa (Mirror Edition)-
Logitech G110
Logitech G15
Note: Please help me justify the PROS and CONS of each keyboard and refer to the System section for what games I play. Thank you
Mouse: Logitech G500 Gaming Mouse
Mousepad: Razer Goliathus Fragged Speed Edition
Headset/Headphones: Logitech ClearChat Comfort Headset
Note: I might or might not buy these since I have a decent headset already. (Feel free for recommendations)
P.S Please note that I am looking at components that are Price: Performance wise. So if you are making recommendations please make them reasonable.
Conclusion:
Overall, I'm a first time builder and so please do not recommend things that are too over complicated to install or use, the simpler the better. I have done extensive research and I am positive that the components I chose are compatible. But feel free to correct me. Oh and if I did violate any rules by accident by posting in wrong sections then please correct me.
Thank you.
P.S I'm apologise for such a long thread but I do wish my build to be mistake-less
www.tigerdirect.com
My Computer Parts:
Case: Nzxt Lexa S
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5222598&CatId=1509
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4588101&sku=A79-0955
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5316156&CatId=3669
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4415284&CatId=4420
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4197086&CatId=2545
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4177125&CatId=2458
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4957045&CatId=3635
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5210453&CatId=3485
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3478779&CatId=802
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4668506&CatId=2533
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3522883&CatId=503
Razer Tarantula-
Logitech G110
Logitech G15
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5214793&sku=L23-0057
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5374227&CatId=45
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3280505&CatId=390
Conclusion:
Thank you.
