Yes No
Ads
Tom's Hardware > Forum > Graphics & Displays > AMD Radeon > 4870x2.. Are temps all right??
Forum Graphics & Displays : AMD Radeon 4870x2.. Are temps all right??
Hi guys!
My 4870x2 reaches temperatures above 90 degrees Celcius when playing games such as crysis... Actually I don't know the max temps for that kind of gpu, and is it normal to have such high temps???
Reply to tobiashensch
90 degree Celsius is too high. Try cleaning your card of any dust around the ventilation and the fan. A safe temperature under load is between 65-75 Celsius. Anything above that might damage your card.
EDIT: forgot to say, but yes, 4870x2 tends to go past 80 degrees Celsius, so this is not out of the norm.
Here is a statement made by ATI themselves: "These temperatures are not too high - that is just perception and relative. We have idle temperatures of up to 80'C on the single-GPU case, and we qualify up to and including over 100C".
I guess you're more safe than I assumed.
Message edited by skolpo on 12-09-2009 at 10:39:50 PM
Reply to skolpo
- 0 +
That card does run hot, but as Skolpo says, give it a clean first, places sell cans of compressed gas for this purpose.
Also check your case airflow, adding an intake fan at the front or side can help as can a PCI slot fan, to draw hot air out from under the card.
Message edited by coozie7 on 12-09-2009 at 10:41:38 PM
Reply to coozie7
There are 2142 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Intel HD 4000 guide
By Sakkura, 3 hours ago:
No, the 6570 is significantly better. For gaming etc. at least - for general PC usage you...
Best offers
Top experts
