Component Seagate 7200.11 1500GB ST1500341AS P/N 9JU138-568 Firmware SD35 Date Code 09133 Site Code TK
PC effected by - PC locked up, rebooted and would not get past BIOS screen. As a fluke i unplugged SATA on another drive the system would boot very slowly with this drive attached but it did not show in bios.
Once i removed the drive from the system i plugged in the other hard drive the system booted normally.
I removed the HD from the pc and put it in a USB external enclosure. on powering it up it will click 4-5 times at an even interval pace and does not initialize.
by the Discription could anyone tell me if this is a BSY / Firmware issue that could be fixed or if it is a physical problem.
-Aaron
-Aaron
