Motherboard PSU connection issue
Ok, my computer was doing this wierd flickering thing when booting and then would blue screen. I was thinking it was the PSU since I replaced the ram and went back to onboard video and the issue was still happening. Now, for some reason, im trying to replace the PSU and it wont connect, not even the original one will go back in. It will go in partially but will not go flush and click in.
This is the mobo
This is the PSU
The mobo is a msi dka790gx platinum.
Never had this issue before. I don't see anything blocking the connection or any pins bent.
Any help is appreciated.
thanks.
1 answer Last reply
More about motherboard connection issue
  1. Are you sure you're trying to insert the connector the right way? Since it's keyed, you can hardly go wrong. On the other hand, you need to apply reasonable, but enough pressure on it.
Motherboards Connection
