Highpoint RR 2720SGL causing BSOD when installing to Existing Win7x64 install (on ICH10R - AHCI) on Gigabyte GA-Z68XP-UD3P
My OS is installed on ICH10R (AHCI) and everytime I boot windows I get a BSOD with the RR2720 card inserted(even without drives connected).
Some things I tried so far (without luck)
1) tried IDE mode in Gibabyte bios for OS SSD (was AHCI)
2) connecting the OS SDD to the RR270 and designated as boot array/volume via RR Bios... still did not work.
3) removed RR2720 and then manually added RR2720 Windows 7x64 driver (via device manager -manual add of store controllers) but still get BSOD.
Questions:
1) Is the RR2720SGL compatible with Gigabyte GA-Z68XP-UD3P ? ( My RR2640x4 never worked with my GA-EX58-UD3R)
2) could the problem be because I set an array up before installing the windows drivers (non OS/bootable RAID-5)??
3) How can I install RR2720 on existing win7 installation and leaving OS drive as is on ICHR10R (under AHCI)?
Do I need to set ICH10R to IDE mode for OS drive to work with RR2720?
Thanks in advance.
Brad
Questions:
Thanks in advance.
Brad
