hey guys,
i was wondering if my water cooling set up will work efficiently, or if i need improvements. i'm planning on water cooling these components:
i7-3820
GeForce GTX 670 (gigabyte windforce)
the case i'm going to use is the SilverStone Raven 1 full tower. the water cooling products i plan to use are:
180mm radiator
bitspower tank z-multi 250 inline reservoir (BP-WTZM250P-IRDBK)
koolance CPU-370SI cpu block
ek-FC680 (since the gtx 670 windforce uses the same pcb as the 680 reference i chose this)
danger den DD-CPX Pro pump
the order i was thinking to do was:
reservoir > pump > cpu > gpu > radiator
will this set up be able to cool my cpu and gpu? my budget for water cooling goes to $400 (CAD) and that includes sleeving materials for my psu.
i7-3820
180mm radiator
