Hi,
I am building a new water cooling loop and I've been looking into multiple brands. I found a neat pump with reservoir from Koolance. I notices many versions of the product and I was looking heavily into the RP-985. It differs from the others because it only pumps around 7L/minute. So my question is, will it be able to pump well with the following set-up:
pump/reservoir>2x140mm radiator>CPU block>120mm radiator>graphics card>pump/reservoir
Also, if you wouldn't mind, could you suggest a tubing size and/or compatible nozzles please?
