Is this what was wrong with my pc???please help
  • Chipsets
  • Graphics Cards
  • Fan
  • Motherboards
June 26, 2010 6:17:47 AM
on June 8 and on June 15 my PC messed up on just a restart...my graphics card(ati 4770) fan keep spinning up and down but no post...so i turn my PC completely off and on(repeated this step) until it turn on...and it did work fine until today(June 25) i woke up and tried to turn my PC on nothing i heard my case fans and my graphics card fan going but thats it so i took out the graphics card nothing happen then i jumped the CMOS and sure enough the pc started fine...but windows 7 said that my index score needed to be refreshed. so i look at my PC spec and it said i had a total of 1GB of ram(i have 3GB of ram)so i turn off my PC and took out the 1GB card and tried to boot with just the 2GB ram card nothing happen my graphic card fan keep spinning(i thank thats due to my motherboard keep restarting trying to use the 2GB stick of ram)so i took out the 2GB card and but the 1GB card in the same slot as the 2GB card was in. presto PC turn on and booted to windows fine.
could this have been my problem the whole time?..funny i play games all the time and i have not had any issues with the 2GB card!! not little games either big games that use more then 1GB of ram like grand theft auto 4 and call of duty 5 ,crisis not 1 BSOD ever... please i really would like(need) help..i know its long but try to read my boring long post
heres the rest of my system
amd athlon x4 620
1GB of ram
asus m4a785-m
ati 4770
antec 300 case
antec 380 watt power supply
More about : wrong
a b U Graphics card
a c 242 V Motherboard
June 26, 2010 1:31:17 PM
If you insert the 2GB module and it doesn't work, then it probably has gone bad. Do both the 1GB and the 2GB modules have the same specs?
June 26, 2010 8:49:54 PM
yes all were the same spec's
i hope this is what the issue was for the past mouth...my graphics card is new i thought it was going bad or moutherboard or my power supply was'nt good enough.
a b U Graphics card
June 26, 2010 9:16:47 PM
If you're positive that the module is bad, then RMA it.
