T tgaston34 Distinguished Feb 20, 2010 2 0 18,510 Feb 21, 2010 #1 Hello, Can you put a Sata 3.0 in an old system the is only compatible to a Sata 1.5 and if so. How do you do it.
enzo matrix Splendid Nov 10, 2009 4,289 0 23,160 Feb 21, 2010 #2 Depends on how old. What expansion slots do you have? Upvote 0 Downvote
13thmonkey Titan Jan 10, 2006 24,798 350 75,790 Feb 21, 2010 #3 should work, may need to set a jumper on the drive to force 1.5, but should autodetect, they are all backward compatible. Upvote 0 Downvote
vvhocare5 Distinguished Mar 5, 2008 768 0 19,060 Feb 21, 2010 #4 They are indeed backwards compatible Upvote 0 Downvote
