Ok, so I'm building a new CoreI3 for someone who needs a new Office PC.
My critical mistake was to buy a 1TB Western Digital Caviar Green drive to
save some money with the current hard drive shortages.
The 1TB Green was even cheaper than the 500GB Blue. In hindsight I should
have bought the blue.
Anyway, I did some research and discovered that I could enhance the
performance by using their Advanced Format Utility and WD Align Tool.
Now it get's confusing, I need to clone the old machine's XP Installation
to the new 1TB drive.
The old machine has 2x 80GB IDE Hard Drives which must be cloned to the
1TB on Separate partitions (I was thinking over 2x ~500GB partitions)
Usually this is a simple task using Norton Ghost, but it appears, since I
need to have XP and 2 partitions on the 1TB, it's not so simple.
Could someone please give me a step-by-step on how to go about this
and where to start?
This is what I've downloaded so far:
Acronis WD Align
Acronis True Image WD Edition
and where to start?
Acronis WD Align
