Water cooling advise?
Ok so i'm gonna get water cooling for my computer that im building and i want to know if it's better to build your own system with separate parts or to just get a kit and set it up that way. i dont have a budget so i want to get the best out there. any help is appreciated
2 answers Last reply
More about water cooling advise
  1. As a newbie to water cooling, the kits are probably the way to go. I'm looking at jumping in myself and have been researching some over the last couple months. The XSPC Rasa kits are cheap ($150 or so) and perform quite well.
    The great thing about "real" water cooling over that closed loop nonsense is you can always upgrade the kit later to better suit your needs. The kits seem like a great starting point to me.
Water Cooling Computer Build Your Own Overclocking
