So after finding many more options, I decided to post another thread with updated parts.
XSPC 2x120mm Radiator Slim + fans
XSPC 120mm Radiator + fans
XSPC Raystorm OR Swiftech Apogee HD (Help deciding please)
Koolance Single Bay Reservoir TNK-501
Swiftech MCP655 Pump (any other suggestions? I'm trying to go 3/8 OD but I saw a video and I know it will work with some tricks)
Koolance VID-NX680
Compression fittings 3/8 5/8
Hose 3/8 ID 5/8 OD
Also, can you tell me if these parts will work together. So will the pump have enough power, etc.
Thanks
Koolance VID-NX680
Hose 3/8 ID 5/8 OD
Thanks
