Recycle bin problem
Hello, When I click onto the recycle icon I get the message that windows has encountered a problem and needs to close down. anideas why this is happening
1 answer Last reply
More about recycle problem
  1. I used google and found some things that may assist you:
    How To Use Google To Search
    in the thread http://www.velocityreviews.com/forums/t753249-windows-explorer-recycle-bin-conflict.html
    it mentions a conflict with other programs:
    Quote:
    it turns out there was another "cleaning" program
    interfering with the Recycle Bin. I had installed a couple of these to
    try them out but neglected to remove them afterward.
    I uninstalled both RedButton and Cleanup Assistant, rebooted, and the
    problem is gone, so one or both of these was the troublemaker.
Windows XP
