Hey all, I joined the site because it looks like the best one out there for solid information on computer parts
I'm making this post because I'm in the process of buying some upgrade parts for my current desktop.
I'm looking to squeeze the motherboard, cpu, gpu, and ram all in a budget of $560. I've been researching my options for days, and my current configuration is as follows:
CPU:
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115215
MB:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128412
GPU:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130440
RAM:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231193
I'm trying to make this the best possible gaming desktop for the given budget. I want to be able to (almost? hopefully?) max out my current monitor's resolution (1680x1050) with almost all high settings. I would also like to be able to do decent on higher resolutions when I get a better monitor down the road.
Thanks for taking the time to read my post, and hopefully you guys have some suggestions/critique about my current config.
CPU:
MB:
GPU:
RAM:
