MSI A55M-P33 review HELP!!
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130641
1 review says Onboard GPU cannot be disabled through BIOS will be this a big problem?
with the A8-3850+HD6670
1 answer Last reply
More about a55m review help
  1. You don't want to disable it anyway (assuming you're planning on CF with the 6670).
Motherboards GPUs BIOS Overclocking MSI-Microstar
