Water cooled 3d workstation both cpu & gpu
hi, im looking to build a workstation for 3d work, with a budget of around 3000 $ , my main councern is the water cooling , i want a cpu & gpu solution , thinking of an quadro fx 1800, xeon or i7 processor, and 8 gigs of ram. any ideias on hardware and final hardware layout? tnx in advanced
2 answers Last reply
More about water cooled workstation
  1. If you're looking at water cooling for silence, then there is no need. The 800D is very (and yes, I mean very) quiet. Intel coolers also have a reputation for silence.
CPUs Workstations 3D Product
