I have a home networking issue I am trying to troubleshoot and having very little luck solving. Here is my setup:
ISP supplied cable modem
Linksys WRT54GL wireless router running Tomato (default settings)
Apple Aiport Express as extender (for AirTunes only)
Desktop running Windows 7 with wired network connection
Laptops with Windows 7 and OSX with wireless connections
HP Printer with wired connection to router
When only the laptops and printer are using the network, everything is peachy. However, every now and then when the desktop comes online it will cause all other connections (it seems including the printer) to drop. Attempts to reconnect will either fail entirely or allow connection to the router but not the internet. If I switch one of the laptops to a wired connection, it will be able to connect to the internet just fine. The only way to get the laptops back online wireless is to reset the router and reboot everything.
Since my wife works at home and depends on an internet connection, I have been avoiding using my desktop all together when she is around for fear of bringing down the network while she is in the middle of something. Anyone have any ideas what might be causing all of this or what might be doen to prevent this? Thanks in advance.
