Sign-in / Sign-up
Diamond radeon hd 4890 and Sony Bravia z series 52'' problem
  • Radeon
  • Diamond
  • HD
  • HDMI
  • Graphics
Last response: in Graphics Cards
December 13, 2009 6:53:17 AM
Hello, I have the following problem. I just bought a brand new video card Diamond hd 4890. I connected my tv to the card via an HDMI cable and DVI-HDMI adapter (provided with the card). My picture on the screen however doesn't fit the entire scree. Catalyst says that its running on 1920x1080/60Hz which is how it should be. Also, the picture is a bit blurry. I have an onboard geforce 8200 with HDMI out and when I was using it I had full screen picture and no blur. Can some help?
More about : diamond radeon 4890 sony bravia series problem
December 13, 2009 3:29:45 PM
this is dur to overscan/underscan : locate the overscan correction settings in Catalyst Control Center and adjust the slider that's there till u get it to fit .
m
l
December 13, 2009 4:07:27 PM
Hi cyberkuberiah, thanks so much for the quick reply. I've adjusted the overscan in the Catalyst Control center to 0%. Now the screen is much better. However, It is not enterly cover all pixels on the 52'' hdtv. I have a onboard geforce 8200 which has an hdmi output and when I connect that it works perfectly fine. The problem is when I play HD content in wmp in full screen. With the 8200 the hdtv automatically adjusts itslef when i switch to full screen. With the HD4890 this doesn't happen. Please advise...
m
l
December 13, 2009 4:57:48 PM
u have another option : use a vga cable , bravia accepts 1920x1080p60 over vga if u have a cable lying around . no overscan problem in vga .
try changing the zoom mode to full2 . in samsung tv's there's is one "just scan mode" , go and explore the settings in the sony tv .
m
l
Anonymous
December 13, 2009 6:58:40 PM
Where do you adjust the overscan option? I've downloaded the latest version of the control center and cannot find it.
m
l
December 14, 2009 2:34:58 AM
Hey you got to Catalyst > Display Options > right click on your display > there were two options (one was Identify) and the other was "settings" I believe -- click on "settings" or whatever it was called > click the overscan tab > adjust the slider
m
l
December 14, 2009 2:40:42 AM
I don't think I want to use VGA becuase its analog and its lossy. When I turn on the card I cannot adjust the zoom on the bravia (ie. Normal, Full1, full2 all display the same image, no change). Any thoughts?
m
l
December 14, 2009 4:41:20 AM
yeah , my vga for 1360x768 has unsharp pixels , i will switch to hdmi . but then hdmi wont support 1360x768 , only 720p, but offer a clear picture
download powerstrip and try changing the settings from there ... but do a google search on powerstip for hdmi 1080p , and then proceed .
m
l
