Hi guys, I am reposting a thread after reading the new build guidelines. Sorry for the previous hasty post.
I was told that there are many people here who are experienced with building computers.
I have built several computers before and wanted your opinions on the following parts. Probably the most important question is whether these parts are compatible.
Suggestions for other options are welcome as I am open to new ideas.
I will overclock the processor and may overclock the memory. I will be running Windows 7 HP x64.
APPROXIMATE BUY DATE: EARLY JANUARY.
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: SPEED IN MINOR TASKS (INTERNET, PROGRAM LOAD, STARTUP, ETC.), SIMULATIONS, GAMING.
I LIVE IN THE USA AND WOULD LIKE TO BUY MOST PARTS FROM NEWEGG.
INTEL CORE I7-860 LYNNFIELD 2.8GHZ: http://www.newegg.com/Product/Product.aspx?Item=N82E16819115214
XFX GEFORCE 9800 GT 512MB: http://www.newegg.com/Product/Product.aspx?Item=N82E16814150323
ASUS P7P55D PRO: http://www.newegg.com/Product/Product.aspx?Item=N82E16813131405
G.SKILL DDR3 1600 4GB 7-7-7-24 (IS 4GB ENOUGH TO RUN WINDOWS 7 x64 AT A REASONABLE SPEED?): http://www.newegg.com/Product/Product.aspx?Item=N82E16820231279
ARCTIC COOLING: http://www.newegg.com/Product/Product.aspx?Item=N82E16835186134
ANTEC 1200: http://www.newegg.com/Product/Product.aspx?Item=N82E16811129043
I already own the following items and will use them.
HARD DRIVE: SAMSUNG 1TB 7200 RPM: http://www.newegg.com/Product/Product.aspx?Item=N82E16822152102
POWER: CORSAIR 750W: http://www.newegg.com/Product/Product.aspx?Item=N82E16817139006
CD/DVD: SAMSUNG: http://www.newegg.com/Product/Product.aspx?Item=N82E16827151171
MONITOR/KEYBOARD/MOUSE/SPEAKERS
Thanks a lot!
Thanks a lot!
