Crashing problem
Last response: in Systems
December 13, 2009 1:49:23 PM
i hav recently purchased a rig-
core i5 750 stock clocks turbomode on
intel dp55wb mobo
ati radeon 5850 stock clocks
250gb hdd
dvd /rw
while playn farcry2 n other games the game automaticaly shuts off after 10m of play n m nt able to understand wats wrong. is it the power supply -
its got 26a on 12v rails i suppose thats nt enuf for my system .please suggest me a how much amperes do i need on 12v rails 4 my system. m on a tight budget so jst how much amperes wud be jst enuf.
More about : crashing problem
December 13, 2009 2:02:37 PM
What brand power supply do you have? How are your temps? Is your power supply rated 80 Plus?
It sounds like the power supply can not handle the load. If your power supply is not rated at 80 Plus these sort of things happen because there is not enough steady juice powering your entire system under full load.
This may also be a defective power supply or might have become unstable recently.
m
l
December 13, 2009 2:16:57 PM
its not rated 80+ though its 550w so m actually concerned bout amperes on 12v rails i hav decided to get it replaced bt m nt sure wat shud i get now .wud 36a on 12v b enuf for this machine
m
l
December 13, 2009 2:32:51 PM
Yeah, I believe that would be your problem. The 5850 will want 500W along with your entire system under full load. If you power supply is not 80 Plus it will not relay enough power to your entire system.
80 Plus power supplies constantly relay their stated power throughout you system and often go over what they specify. Power supplies not rated 80 plus or higher will stop at their designated level like 550W. If you had purchased an 80 Plus power supply I'm pretty sure you would be all good.
This power supply will do the trick! $79.99 and a $10.00 mail in rebate.
m
l
