Power supply confusion
  • New Build
  • Power Supplies
  • Cases
  • Systems
  • Product
Last response: in Systems
December 13, 2009 5:19:12 PM
Hi, I'm building a new system and using an old case which I'm not sure if it will hold a newer power supply. The case is from 2004, its an ENERMAX and there's a sticker on it saying "Designed for ATX 12V Ver 1.2".
What does this mean? Can anyone tell me what power supply options are available to me for this case. I think I'll go with a 550 or 600 watt for hi-end audio recording/production?? I'm just not sure about which one to get that will fit this case and have all the connectors I need for the other hardware I'm using for this build. How do I figure this out? Below is what I'm putting into it. The PSU in it right now is a (ENERMAX, model: EG301P-VB) Any advice on which PSU to get would be awesome. -Thanks!
Motherboard: GIGABYTE GA-EP45-UD3P LGA 775 Intel P45 ATX Intel Motherboard
CPU: Intel Core 2 Duo E8400 Wolfdale 3.0GHz 6MB L2 Cache LGA 775 65W Dual-Core Processor
RAM: (qty 2) of Mushkin Enhanced Blackline 2GB 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Desktop Memory Model 991599
Harddrive: Western Digital VelociRaptor WD1500HLFS 150GB 10000 RPM 16MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive
Harddrive 2: (qty 2) Raided 120 GB generic SATA Maxtor drives
Grahics Card: old nvidia geforce, 128mb onboard
Sound Card: EMU 1212m PCI
DVD-RW drive
More about : power supply confusion
December 14, 2009 12:45:13 PM
ATX is a motherboard form factor standard that has been around for ages. It means it fits any ATX parts like mobos & psus:
http://en.wikipedia.org/wiki/ATX
The Corsair is high quality, but overkill for your outdated pc which uses IGP (onboard video). You can get by with a 400-500W PSU. This will suffice:
Do you plan to upgrade the video sometime in the future? If so, you should decide on the video 1st, then psu. However, a 600W will power most modern gpus.
m
l
