Tom's Hardware > Forum > Mobility Networks > Cingular > strange noise from phone
Forum Mobility Networks : Cingular - strange noise from phone
Archived from groups: alt.cellular.cingular (More info?)
It sounds like I have a mosquito trapped in the earpiece speaker portion of
my LG 1400. It makes this faint bzzz bzzz bzz noise when just sitting on
the table. This is the second time I have noticed it in the last couple of
days. Last time I took the battery off and reset it, and it stopped. Is it
some kind of wireless upgrade or is my phone going to explode soon?
Thanks,
Michelle
Sponsored Links
"Michelle" <mishellr71@netscape.net> wrote in message
news:5A6Yd.81654$Dc.58156@trnddc06...
> of
> of
> it
> Thanks,
> Michelle
I doubt it's a wireless upgrade, but i really really hope it won't explode.
That would be bad.. How would you explain that to your carrier or your phone
insurance people. wow!
Reply to Anonymous
"Danska" <danskaNOSPAN@gmail.com> wrote in message
news:g-Odnc1t_5phaq3fRVn-qw@comcast.com...
explode.
phone
I really hope it doesn't explode either! I was just joking. Seriously
though, I wonder what it is. I left it alone and it stopped when someone
called. Weird.
Thanks,
Michelle
Reply to michelle
Taking a moment's reflection, Danska mused:
| explode. That would be bad.. How would you explain that to your carrier
| or your phone insurance people. wow!
If he's talking on it at the time of explosion, he won't have to explain
anything. ;-)
Reply to Anonymous
- 0 +
move it away from the computer screen and it should stop making those weirde
sounds.
larry
> of
> of
> it
> Thanks,
> Michelle
Reply to Larry
If the noise is coming from the phone itself, and not a radio or amp
nearby, then your sound settings might be wierd. I don't know how that
would happen, but you could try resetting the audio gain settings to their
default values:
Type 2945#*# to get to the Test Menu. Select Baseband (2), Audio Gain
(8)and Default Value (5). While you're at it, could you go to "L1400
Vers" and post what it says?
LP
> Thanks,
> Michelle
Reply to Anonymous
"Larry" <2root@sbcglobal.net> wrote in message
news:KvCYd.5490$yp.1189@newssvr11.news.prodigy.com...
weirde
> sounds.
> larry
I thought of interference, but even in the garden it was buzzing. Thanks
for the tip!
Michelle
Reply to michelle
"Lars Peterson" <lars.peterson@gmail.com> wrote in message
news:pan.2005.03.12.15.48.13.636688@gmail.com...
> default values:
> LP
Thanks for this information - I never knew about the "test menu". Ok, I did
as instructed and reset the default value. Also, I made a mistake, I have
an LG1200 not 1400. The Vers says:
**Cingular**
L1200P40
V0.8.5
1-310-170
Apr 22 2004
What info can you glean from this, and what does it mean?
Thanks for the help!
Michelle
Reply to michelle
On Sat, 12 Mar 2005 17:37:20 +0000, Michelle wrote:
<SNIP>
> **Cingular**
> L1200P40
> V0.8.5
> 1-310-170
> Apr 22 2004
> Michelle
Not a lot. I thought it might be a bug in the phone's software, either a
newer or older version than I have. (L1400)
Have you called Cingular Customer Service?
LP
Reply to Anonymous
news:pan.2005.03.13.04.43.24.478767@gmail.com...
> <SNIP>
> LP
Naa, it's working fine, just the weird intermittent noise, which hasn't
happened yet again. I'd probably waste a lot of time on the phone over a
fluke problem that they couldn't help me with anyway.
Thanks again for your help,
Michelle
Reply to michelle
There are 1287 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
