More than 1 type of ATX power supply pin out?
Richard Lewis Haggard
Is there more than 1 ATX power supply pin out? The reason I ask is because I built some ASUS P4B motherboard based systems a couple years back and put 350 watt ATX power supplies into them at the time. I had reason to upgrade the PS to 500 watt units and bought some that said that they were ATX power supplies - but they don't fit. The plug that goes to the mother board is slightly larger and has an extra pair of pins on it. What power supply should I have gotten?
So you think I have a new ATX power supply that has 4 more pins than are on the older ASUS P4B motherboard and that it should be possible to use the power supply anyway? As soon as I saw that the motherboard power connector had fewer pins than the power supply, I did not attempt to make the connection. In the brief amount of time I spent in disbelief before engaging in a meltdown, it looked to me like they were slightly different sizes as well. I will go back and look closer.
Or maybe there is a cable adapter that will do the trick?
