Hi, hopefully someone is able to help me with this issue because I've been searching all over the internet for a solution. But here is what happened: I just recently (like over the winter) got a new CPU, MB, and RAM. And when I first got all of these I got them installed etc. (after a difficult hair pulling process lol) but then I finally wanted to overclock my CPU because I mainly play FSX which relies a-lot on CPU power. so I wanted to overclock to 4.0+ Ghz which I accomplished successfully by just changing the CPU multiplier. But recently I have been getting BSODs and I tracked it to my system being unstable from the overclock, so yesterday I just reset the BIOS to the Default settings so I wouldn't do any damage, so anyways this morning when I woke up I got on my computer and checked my email etc. and I had to get some things done until I was finished and had sometime, so I decided to work on overclocking. So what I wanted to do was make overclocking easy lol because I don't have all day. But I do wan't a good stable overclock, so I just searched on Google "how to overclock" and went to a 12 step page on how to do it that made it LOOK pretty easy lol...and that may have been my 1st mistake is going to this website (http://www.wikihow.com/Overclock-a-PC). But I followed their directions, and to see if my CPU was unlocked or locked (I already knew, but I did it anyways...lol) I lowered my CPU multiplier and rebooted, and everything was going fine. So then I rebooted and moved on to step 6 and that's when it got funky...the instructions said to raise the FSB...and I couldn't find the FSB settings in my BIOS so I googled (on my iPad) how to change FSB with an AMD proccessor or something like that...and I founf out that the newer AMD proccessors don't have a FSB but they use Hyper-Transport Frequency or something like that lol, so what I decided to do...may not have been the wisest idea, but I raised the HT Frequency a few notches. And then I restarted my PC. So after I restarted, all of my fans light up and started spinning, like when your PC is booting up normaly. But no display showed up, so I just thought I over did it. So I shut it down and tried to reset the CMOS...via jumpers, unplugging computer, taking out battery. And I tried each of these several of times. And nothing has changed, the fans still spin but no display. I really hope someone can help and also I would greatly appreciate anyone that could help me out on overclocking since I'm an idiot...and if I should even of been using that website to overclock.
My PC Specs: (if you need more of my specs just let me know)
CPU: AMD Phenom II X4 970 Black Edition Deneb 3.5GHz Socket AM3 125W Quad-Core Desktop Processor HDZ970FBGMBOX
RAM: CORSAIR Vengeance 8GB (4 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 Desktop Memory Model CMZ8GX3M4X1600C9G
MB: GIGABYTE GA-990FXA-UD3 AM3+ AMD 990FX SATA 6Gb/s USB 3.0 ATX AMD Motherboard
PSU: Antec High Current Gamer Series HCG-750 750W ATX12V v2.3 / EPS12V v2.91 SLI Certified CrossFire Certified 80 PLUS BRONZE Certified Active PFC Power Supply
Well, anyways I greatly appreciate everyone in advance for their help!
-Thanks, Clay
-Thanks, Clay
