The only concerns I'm having is with my PSU...
http://www.newegg.com/Product/Product.aspx?Item=N82E16817159040
if I have to replace it, would the newer ones work for my old system without screwing things up? I found this one... http://www.newegg.com/Product/Product.aspx?Item=N82E16817182199&cm_re=power_supplies-_-17-182-199-_-Product
my spec:
ASUSTek Computer INC Mobo (A7N8X Deluxe)
AMD Athlon XP: Thoroughbred, Socket A 2700+
3 gigs of RAM (Corsair 2 sticks regular of 1 each, and the 3rd XML)
GeForce 5500
PLANET WL-8310 Wireless Card
200G Seagate (Master)
500GB Wester Digitital SATA
LG DVD Writer
Coolmax AP-550X Power Supply
WinFast TV2000 XP Expert WDM TVTuner
3 Fans cooling my system and thinking of getting the big (99mm i think) on the TOP of the tower when getting 7800 GS.
you think it can handle it? SpeedFan says I'm getting 11.80 under 12V+
my spec:
GeForce 5500
LG DVD Writer
