Can ZIF and LIF connect the same flat cable?
  • Hard Drives
  • SSD
  • Connection
  • Storage
Last response: in Storage
November 21, 2011 7:59:12 PM
Hello,
I would like to change my MK1214GAH hard drive for a SSD. But I am confused with the LIF/ZIF.
I read that the MK1214GAH has a LIF connector
http://storage.toshiba.eu/export/sites/toshiba-sdd/medi...
And I also read that some people managed to connect a ZIF SSD instead of the MK1214GAH.
So my question is, are ZIF and LIF just 2 ways of connecting the same flat hard drive cable?
Thank you for your help and your answers!
Best regards,
D.N
More about : zif lif connect flat cable
a c 415 G Storage
November 22, 2011 3:36:24 AM
"ZIF" stands for "Zero Insertion Force", and "LIF" stands for "Low Insertion Force". They're both talking about the same kind of ATA connector. The idea is that there's a locking mechanism that clamps down on the contacts to give a good electrical connection, but that mechanism can be released to make it easy to insert or remove the cable.
So the short answer is: yes - they both work with the same cable.
November 22, 2011 11:19:01 AM
Thank you sminlal!
May 28, 2012 7:10:35 PM
iceman_zen said:
Thank you sminlal!
Which SSD did you replace MK1214GAH with iceman? I am planning to replace MK1214GAH in my TZ37GN with a SSD but unable to find a compatible SSD.
