Tom's Hardware > Forum > Home Theatre > ReplayTV > Channel Guide wrong channel
Forum Home Theatre : ReplayTV - Channel Guide wrong channel
Archived from groups: alt.video.ptv.replaytv (More info?)
My channel guide has the wrong info, HBO and local Fox station are switched.
Every online TV listing has the same problem, so the problem is from the
Cable TV co. Anyway to correct this? Am I destined to manually record
everytime I want to capture a program on these 2 channels?
www.operationuplink.org
Sponsored Links
If you have correctly selected the cable service you actually use, and the
Replay Guide is wrong, I suggest sending ReplayTV technical support a
detailed e-mail with all of the particulars.
It is, however, likely that you selected the wrong cable service during
setup. I suggest carefully reviewing your setup.
Bye.
"Xavier Onassis" <xavier-onassis@comcast.net> wrote in message
news:CdOdneUykf2HCp_cRVn-rw@comcast.com...
switched.
Reply to Anonymous
I was missing a channel. I emailed Tech Support, I got a response within 30
minutes, and 2 days later, the channel was back on my guide.
So I suggest an email.
switched.
Reply to Anonymous
There are 1217 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
Related Content
