Will GeForce 7600 GS AGP work with my PSU?
and with all the current things I'm running? there is one on ebay that ends in 40 mins... and I think with my speed this COULD be a good card. Only I got 18A on 12V+ but I think it needs 20A so I dont know...
my spec:
ASUSTek Computer INC Mobo (A7N8X Deluxe)
AMD Athlon XP: Thoroughbred, Socket A 2700+
3 gigs of RAM (Corsair 2 sticks regular of 1 each, and the 3rd XML)
GeForce 5500
PLANET WL-8310 Wireless Card
200G Seagate (Master)
500GB Wester Digitital SATA
LG DVD Writer
Coolmax AP-550X Power Supply
WinFast TV2000 XP Expert WDM TVTuner
3 Fans cooling my system and thinking of getting the big (92mm i think) on the TOP of the tower when getting 7600 GS.
you think it can handle it? SpeedFan says I'm getting 11.80 under 12V+
9 answers Last reply
More about will geforce 7600 work
  1. That PS more than enough for 7600GS. For ref I ran one on 350W Celeron system.
    Try this PS calculator.
    http://www.thermaltake.outervision.com/
  2. 7600 GS AGP wouldn't need much power...
    I say that u are good with that psu...
  3. That PSU will be fine.
    Go for it.
  4. just ordered it today.
    question about PSU.. does "30amps on 12 volts" mean same thing as saying 20A on 12v? whats the difference between 30 amps and 20A? I never understood this.
  5. 30A on 12v mean:
    30 x 12 = 360 watt
    20A on 12v mean:
    20 x 12 = 240 watt
  6. but but PSU says 18A under the +12V... so my CPU is 30A even though it says 18?? im confused
  7. It has 2 12V rails (+12V1 and +12V2).
    It has 2 Rails with 18A and 16A.
  8. I'm confused too about your statement above...
    Anyone could help us?
Nvidia Graphics
