For quite a while now, I've been getting a very loud beep the instant i turn on the computer. The screen stays black for maybe 5 seconds, and then it turns on completely normal, and everything works perfectly. It doesn't take away my fear of something being very wrong though..
As far as I can remember, it's beeps gradually came. It didn't beep at all startups.. But the last 4-5 months it has just beeped at all startups. I don't think it is just the normal POST, because, as i said, it's very loud, and also, it lasts for 2 seconds or so. My memory is in slot number 1, 3, and 4 (I had it in 1,2 and 4 before, no difference between the two options).
These are my specs:
- Gigabyte GA-EX58-UD3R
- 3 x Corsair XMS3 DDR3 1333MHz 2 CL9
- Intel Core i7 920 (It has been overclocked for a while, but turned off now for fear it was causing the beep. No change in beepyness however.)
- Nvidia GeForce GTX 285
In advance, thank you.
~Quantonium
These are my specs:
~Quantonium
