Archived from groups: alt.games.the-sims-2 (More info?)
Hi all
previously I could double click on a package file on this computer and it
would install but now when I try to double click on a package file the sims2
content installer says that I need to double click on a package file to
install the content.
I don't understand why it would ssay this now after being able to install
before.
This problem sends me into an endless loop where I cannot install anything.
Do I need to reinstall some sim2 content installer file?
if so, where do I find it?
thank you
"Mike and Chey" <mikechey@direcway.com> wrote in message
news:35vj1uF4rihbcU1@individual.net...
> Hi all
> sims2 content installer says that I need to double click on a package file
> to install the content.
> before.
> anything.
> thank you
> Chey
Hi Chey:
If the item says .package then all you have to do is put the items into the
following folder:
My Documents\EA Games\The Sims 2\Downloads
If the item says .sims2pack then just double click the item and it will
install itself!
I had the same problem till I figured
out the difference.
Hope this helps
Barb
ahhh ok thank you so very much
Chey
"Barbara Buckley" <BBuckley58@verizon.net> wrote in message
news:qsFKd.519$UB6.244@trnddc01...
>> Hi all
>> file to install the content.
>> before.
>> anything.
>> thank you
>> Chey
> Hi Chey:
> the following folder:
> install itself!
> out the difference.
> Hope this helps
> Barb
