APPROXIMATE PURCHASE DATE: Less than two weeks BUDGET RANGE: $1400 After Rebates
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: Running Engineering Simulations (CFD, etc.) and Gaming (Team Fortress 2, rFactor, etc).
PARTS NOT REQUIRED: Keyboard, Mouse, Speakers, OS (Windows 7), DVD Burner, etc.
PREFERRED WEBSITE(S) FOR PARTS: newegg.com, tigerdirect.com, I really don’t care
OVERCLOCKING: Someday SLI OR CROSSFIRE: Maybe
MONITOR RESOLUTION: See below
ADDITIONAL COMMENTS: I’m really new to everything here so that’s why there are so many gaps in my parts list. I know how everything goes together and won’t have any problems bui
lding it, but I need lots of help trying to figure out what are the best parts. I’m really going to use this computer for Engineering Simulations so I wanted an i7 processor since it’s pretty much the new standard. I’m also still up in the air monitor wise since this is going to be my first desktop ever so I don’t know what is a reasonable size. Also, I’m going to be doing some gaming (TF2, rFactor) and would like these games to run at full settings but to be honest I’m not going to be pushing the limits graphically.
ASUS VW246H Glossy Black 24" 2ms(GTG) HDMI Widescreen LCD Monitor 300 cd/m2 ASCR 20000:1 (1000:1) Built in Speakers - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236049
I’d appreciate some input on this monitor. It got pretty decent reviews and 24” seems like a reasonable size. I don’t want to go much bigger.
Antec Nine Hundred Two Black Steel ATX Mid Tower Computer Case - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129058
Pretty nice looking case. Not too obnoxious in my opinion.
Seagate Barracuda 7200.12 ST31000528AS 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148433
OCZ Vertex Series OCZSSD2-1VTX30GXXX 2.5" 30GB SATA II MLC Internal Solid state disk (SSD) - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227393
LG Black 24X DVD+R 8X DVD+RW 16X DVD+R DL 24X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM SATA DVD Burner - Bulk - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136177
ASUS P7P55D-E Pro LGA 1156 Intel P55 SATA 6Gb/s USB 3.0 ATX Intel Motherboard - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131621&cm_re=Asus_P7P55D_PRO-_-13-131-621-_-Product
Intel Core i7-860 Lynnfield 2.8GHz 8MB L3 Cache LGA 1156 95W Quad-Core Processor - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115214
XFX HD-577A-ZNFC Radeon HD 5770 (Juniper XT) 1GB 128-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFireX Support Video Card - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150447
Antec TruePower New TP-750 Blue 750W Continuous Power ATX12V V2.3 / EPS12V V2.91 SLI Certified CrossFire Ready 80 PLUS BRONZE Certified Active PFC "compatible with Core i7/Core i5" Power Supply - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371022
OCZ Platinum 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model OCZ3P1333LV4GK - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227478
