Hello, I recently upgraded to an Intel Core 2 Duo E8400 from an E6600 and I have been experiencing various problems since. Here is my set up...I will explain the problems following...
OCZ GameXStream OCZ600GXSSLI 600W Power Supply
ABIT AW9D-MAX LGA 775 Intel 975X ATX Intel Motherboard Bios 17 (I believe)
WD Raptor 150GB
Kingston HyperX 4GB (4 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400)
SAPPHIRE Radeon HD 4870 1GB
After making the upgrade to the E8400 I have had problems booting to bios on several occasions. Most of the time the bios settings won't recognize the bus speed at 340 mhz (x9) and will set it at 133 mhz. When I change it back to the default, everything runs smoothly. However, recently, when I run something demanding, like a game, my system crashes like it has been unplugged from the wall. After several attempts to reboot, my system would not get to the bios to even begin starting windows. I have been stable now with the bus speed set at 133 mhz. My idle temps (running several instances of mozilla, CPU-Z and SpeedFan) for both bus speeds of 340 mhz and 133 mhz have been 37C. I will test using Prime95 and see what the temps go to then and post the results.
Does this sound like a power supply issue? I am banging my head trying to figure it out.
WD Raptor 150GB
