On board audio can be disable in two ways: BIOS or Windows.
Prefabricated systems may have less wiggle room, so if you can't find the BIOS setting, disable the onboard auido controller from Windows.
Go to Control Panel -> Device Manager -> Sound, video and game controllers
Right click the device you want to disable, then select disable.
