Ok. I got my mobo RMAd after the PC wouldnt run at all.. no fans.. nothing
So they sent me a new one.. and I hooked it all up.. and now all the fans will run but I get no beeps and no video display. Also, my cd drive doesn't come on or light up. (Not sure about the HD.. cant tell)
I changed power supplys and the same thing happens.
Biostar suggested that its probably a CPU issue because if there are no beeps .. he says thats usually a mobo/cpu issue.
My question is why isn't the CD drive working? Could have a power surge knocked out the CPU, Mobo, CD drive.. and potentially the harddrive? The videocard still spins up fine.. as do all the fans I hook up to it.
Looks like I might have to RMA the CPU now.. and I willjust buy a new CD drive if I have to.
