Hi all,
I recently finished putting my rig together
ASRock Extreme4 GEN3 p67 mobo
intel i5-2500k
Noctua NHD-14
Crucial M4 64GB SSD
Samsung 320GB 7200rpm HDD
2x 6870 (CrossFire)
and built it with no problems. Since my Samsung HDD was already used in a previous build and already had W7 installed, i booted up the PC with no problems. I did not install any drivers and no components were in a "conflict". I did however, run into a problem with my SSD and my DVD drive. The DVD drive problem is no biggie, it is not recognized in the BIOS, and since its not recognized i cannot boot from it (since i want to reinstall w7 on to the SSD) but it does function within windows, with the icon and all that. The SSD however, was recognized in the BIOS, but not in windows. So i took some time to research and found out i could fix it via Disk manager. And so i did, I initialized the drive, and formatted it to NTFS and it showed up on the computer, all ready to use. Then, when i rebooted, the SSD was not shown on My Computer as a hard disk drive, only the HDD. So i went back to device manager and it said it was all healthy and online, but when i tried to format it, it gives me an error message saying the device manager needs to be refreshed etc. then when i deleted the drive again and tried to partition it , it gives me the same message. Currently, i ran DiskPart, and cleaned the drive, tried to format for use again, without success. I then used the clean all command, and it showed 59gb available out of 59. Tried to format again, without success..what could be wrong? if it worked normally in the first place its not broken..everything else works perfectly..
PS: the very first time I partitioned the SSD, (using quickly partition) named it S: SSD and it did it in about a second, I thought it would have taken at least 3 minutes..and then it was working fine, rebooted PC and then not functioning...
Thanks in advance
intel i5-2500k
Noctua NHD-14
Crucial M4 64GB SSD
2x 6870 (CrossFire)
Thanks in advance
